TwinTurbo.NET: Nissan 300ZX forum - Fuel tank has drain bolts on the bottom of each side. (n/m)
ttz'in (NorCal)
on September 08, 2014 at 3:37 AM
Need help "jumping" fuel pump in order to drain tank
posted by John PGT
on September 07, 2014 at 11:54 PM
John PGT
23:54:20 09/07/14
Fuel tank has drain bolts on the bottom of each side. (n/m) -
ttz'in (NorCal)
03:37:47 09/08/14
^Yeah (n/m)
-Grimm-
06:48:11 09/08/14
Thanks, I already knew about the drain bolts, but...
John PGT
10:38:50 09/08/14
Re: Need help "jumping" fuel pump in order to drain tank
agent4573
16:33:18 09/08/14
Re: Re: Need help "jumping" fuel pump in order to drain tank
agent4573
16:38:03 09/08/14
If you dont want to use the drain plugs, just run a siphon
ZXoltan
18:13:31 09/08/14
Figured it out, I'm all set (more within...)
John PGT
00:32:51 09/09/14
any ideas on a switch? so you can go 91, 110, etc.
wickdGSXR
23:25:47 09/09/14
Sounds like you want a 2 tank setup....
John PGT
13:52:31 09/10/14
